Fail to publish webtool print function to Enterprise with ArcGIS Pro
8379
23
02-22-2018 06:15 PM
QiranLiang
I was trying to publish a Services for printing with ArcGIS pro follow by this article:Tutorial: Publishing additional services for printing. Although the webtool was successfully published and appears in the Server Manager and the portal. Every time I try to run it it all return a error. I try to click on the error, but nothing shows up. I already have Arcgis data store up and running, and was able to publish and run other geoprocessing tool such as buffer.
TanuHoque
Unfortunately at this point, if I say something that'd be nothing but throwing darts in the dark. Could you pls contact support?
QiranLiang
I already contacted them a month ago, but still no solution.
TanuHoque
one other thing: did the out of the box printing service (i.e. http://localhost:6080/arcgis/rest/services/Utilities/PrintingTools/GPServer ) work for you?
QiranLiang
Sorry for the late reply, could you give me more info on how to apply this service?
TanuHoque
just copy of the url of the service and paste that as the url while configuring your web app builder print widget
QiranLiang
it said it's not a print service.
TanuHoque
QiranLiang
it said the url is not available
TanuHoque
you might need to replace 'localhost' with machine name that is hosting arcgis server.
localhost refers to your machine that you are working on and it seems like the printing service may not be hosted on your machine...
can you try with 'https://gis.engeo.com/arcgis/..... (as per the screenshot you posted earlier)
if that does not work, I will highly recommend you to check back with Esri Support.
QiranLiang
it doesn't work, I will call them again.
