Extract Features From MapServer/ Rest/ Soap/ etc?
28700
42
01-15-2015 07:04 AM
JustinMeyers
Is it possible to extract gis data (features, records, geometry, etc) from arcgis rest/ soap/ Mapservers?
For example: ProxyServices/DDOTBaseMapProxy (MapServer)
can i extract the first layer
and make it a shapefile/ feature class, etc?
Thanks!
Juan_JulioLiñan_rebaza
Yes, you're right, Jake, thanks for the answer. I was hopping to find a way to handle this kind WMS services to download its feature data. Thank you for you attention and time.
Hi Jake, happy day.
Could you help me on how to handle this kind of errors, please. Maybe a query sentence that i can use.
1. This error appeared when i was trying to download this feature layer
http://sinpad.indeci.gob.pe/arcgis/rest/services/SINPAD_2018/MapServer/215
2. This second error appeared when i was trying to download this feature layer
http://sinpad.indeci.gob.pe/arcgis/rest/services/SINPAD_2018/MapServer/204
Thank you for your time and attention.
Regards,
Juan Julio
JakeSkinner
Esri Esteemed Contributor
Juan Julio Liñan rebaza‌ it looks like this service was published without the SHAPE field enabled, so you won't be able to download the geometry of this service.  However, you can download this as a table if that is helpful:
Hi Jake, thank you for your time. Look, when i try to download the tabular data from this feature layer
i get this error:
On the other side, whe i try to download the feature data from this feature layer, using a query statement
I exported the feature. This means that the shape field is enabled right?
Is there a better way to use query statemets to download only the valid geometries or "downloadable features'?
I was tryng to do the same process with the other feature service but with no succes.
When I try to use the same query  on the web to export a KMZ, it is succesfully done.
Is this another probe that the shape field is enabled? Is there a way to export all the fields into a kmz format?
Thank you for your help. I'm tryng with all possibilities.
Regards
Juan julio
JakeSkinner
Juan Julio Liñan rebaza‌ looks like KMZ may work.  You can specify your query, and specify an * for the Out Fields parameter.  This will return all fields.
Once you have the KMZ file, you can use the KMZ To Layer tool to convert the data to a File Geodatabase.
Thank you Jake, after excecute the tool it generates a layer with all the data in a field called PopopInfo in a XML format. There is a tool or a way to corvert it to a table?
Thank you again. All you have told me has been really helpful.
Regards,
Juan Liñan
XanderBakker
with Python:
the simple way: https://community.esri.com/thread/118781#445348
or using a little more advanced: https://community.esri.com/thread/118781#445572
JustinMeyers
can i do it with this dataset?
JakeSkinner
Yes, I was able to do this with the tool I referenced.  Attached is a feature class within a File Geodatabase.
JustinMeyers
Thanks for the update.  I cannot get the tool to work for some reason?  Do I have to edit the python code?  Also, the feature class attribute table shows 77,994 records, but the actual geometry has way less?  The attached picture shows in red where the features are (the black is just a admin 1 boundary of indonesia).  I dont think the tool actually grabbed all the geometry (unless you stripped out the geometry and just kept empty records for size?)?  Please let me know.
Thanks!
