Extract Features From MapServer/ Rest/ Soap/ etc?
28771
42
01-15-2015 07:04 AM
JustinMeyers
Is it possible to extract gis data (features, records, geometry, etc) from arcgis rest/ soap/ Mapservers?
For example: ProxyServices/DDOTBaseMapProxy (MapServer)
can i extract the first layer
and make it a shapefile/ feature class, etc?
Thanks!
Gijsvan_den_Dool
Gijsvan_den_Dool
Morning Jake,
Did you have any luck with the URL I provided? Perhaps my cache too small or connection is not stable enough. Would it be possible to break the dataset into smaller parts (like 1-degree tiles)? I don't know enough about the rest service to set this up, most appreciated if you could get me some pointers.
Best regards,
Gijs
JakeSkinner
Esri Esteemed Contributor
Gijs1973‌, unfortunately I did not.  I was only able to get 700,000 features downloaded.  I can't say for sure what is going on, but it could be that the service is at 10.0.  When I wrote this tool, it was at 10.1 when there was an architecture change to ArcGIS Server.
Gijsvan_den_Dool
Thanks Jake,
At least we get the same number of features returned!
Do you have any (other) suggestions on how I could obtain the data from this service?
Juan_JulioLiñan_rebaza
Hi Jake, your tool is cool. Thank's for sharing. I've been downloading some wms, but then i found a wms server which i'm having troubles and i hope you could help me to handle it.
http://sige.inei.gob.pe/cgi-bin/mapserv?map=/var/www/html/test/atlas/map/mapa_negocios_cp.map
I note that this url has a different structure from ArcGIS services. How can i handle this kind of wms features to download its feature data.
Thank you very much.
JakeSkinner
Is this the URL of the data you would like to download?
http://gisem.osinergmin.gob.pe/arcgis/rest/services/MINERIA/MINERIA_OE/MapServer
Hi Jake, I was trying to download the features in that URL with no success, I just downloaded the tabular data.
But most important is this URL
MapServer Message
Which I cannot access using arcgis online either.
Thank's Jake
JakeSkinner
I get an error when trying to access that URL:
Yes, Jake, I get te same error too, but that's the right URL. You can access it using JOSM as is showed here.
Mapeo calles + nombres usando sige.inei.gob.pe · Issue #1 · osm-pe/mapping · GitHub
The WMS i'm trying to download is used for this web map application.
Sistema de Consulta de Centros Poblados
JakeSkinner
Looks like the layer is a WMS layer, which I believe you mentioned before.  This tool will not be able to download data from a WMS layer, only ArcGIS REST services.
