Exporting to shapefile
791
04-28-2025 02:54 AM
Hlynur
Hello, our users come up with the same question again and again and that is if it will be possible in Enterprise 11.4 or 12 to export from select and query widgets directly to shapefiles? No workarounds or tricks, just in in a web Experience, run a selection or a query, select the format shapefile and get their results in that format.
Hosting data is and will not not enabled on our setup nor will every user have a creator license.
So as of today our users cant select shapefiles for export and we just want to be clear to our users if that is something upcoming or not?
So far I have not seen that in any documentation regarding Enterprise 12.
RyanUthoff
MVP Regular Contributor
I do not believe it is possible to export shapefiles in Experience Builder. I just looked and do not see any options to export to shapefile, nor do I see anything in their documentation. Someone already created this idea for Esri to implement as well. https://community.esri.com/t5/arcgis-experience-builder-ideas/extract-data-widget-in-experience-buil...
Of course there are workarounds to that, but if that's not what you're looking for, then it's not possible.
