Export data from Map Service
18101
14
10-23-2014 03:35 AM
HaniDraidi
Is there a tool (in ArcMap) to extract data from a map or feature service I am accessing?
Thank you,
Hani
OLANIYANOLAKUNLE
Hi Jake Skinner, I found your tool very useful and helpful but I still get the error below;
iteration = int(data['OBJECTIDS'][-1])
KeyError: 'OBJECTIDS'
See my code block below as well;
username = "ASDERT"
        password = "@######"
        baseURL = 'http://services5.arcgis.com/b23aIR8OqGRlfJlE/arcgis/rest/services/PropertyEnumerationForm/FeatureSer...'
        arcpy.AddMessage('\nGenerating Token\n')
        tokenURL = 'https://www.arcgis.com/sharing/rest/generateToken'
        params = {'f': 'pjson', 'username': username, 'password': password, 'referer': 'http://www.arcgis.com'}
        req = urllib2.Request(tokenURL, urllib.urlencode(params))
        response = urllib2.urlopen(req)
        data = json.load(response)
        token = data['token']
        # Return largest objectIds
        params = {'where': '1=1', 'returnIdsOnly': 'true', 'token': token, 'f': 'json'}
        req = urllib2.Request(baseURL, urllib.urlencode(params))
        try:
            data['objectIds'].sort()
        except:
            arcpy.AddWarning("\nURL is incorrect.  Or, Service is secure, please enter username and password.\n")
        minOID = int(data['OBJECTIDS'][0]) - 1
        OID = data['objectIdsFieldName']
Kindly assist me with this, Thanks
JakeSkinner
Esri Esteemed Contributor
Hi Olaniyan,
When running the tool on the service, I did not receive any errors.  Ex:
OLANIYANOLAKUNLE
Thanks Jake,
I was trying to run the script behind a button, see script below;
import pythonaddins
import os
import datetime
import time
import os, sys
import urllib, urllib2, arcpy, json
import uuid
class AGOLClass1(object):
    """Implementation for AGOL_addin.button (Button)"""
    def __init__(self):
        self.enabled = True
        self.checked = False
    def onClick(self):
        username = "TAXXXX"
        password = "#######"
        try:
        except:
        iteration = str(data['objectIds'][-1])
        minOID = str(data['objectIds'][0]) - 1
and I get the error below;
  File "C:\Users\KUNLE\AppData\Local\ESRI\Desktop10.2\AssemblyCache\{322E160C-A3DE-48C9-BEBC-86802FD9C785}\AGOL_addin.py", line 40, in onClick
KeyError: 'objectIds'
But the script runs well as a script tool under a toolbox. Kindly assist, thanks.
TanuHoque
Thanks Jake Skinner‌ for the python script. This is awesome!
Just an FYI for all - in ArcGIS Pro, you can use geoprocessing tools such as 'Feature Class to Feature Class' to export data from a layer off a map service. And you can download all data not just first 1,000 or whatever is MaxRecordCount is set to (as long as the server is not an older version).
Steps
Esad
I am trying to fetch data from a map server that I do not manage and I am receiving the following error:
Proxy server got bad address from remote server (verify the server is running). (status code 504).
