Export cached tiles by iOS
1838
07-28-2014 09:21 AM
MaxFelinger
Hello together,
I am using the iOS runtime SDK. The users should be able to use my cached tiles offline. The SDK provides methods for estimate and export (download) tiles. I have tried both. Both works with the esri example service (sampleserver6). But does not work with my own cached tiles. I have activated "Allow clients to export cache tiles" for my map service. It's the same when I am using the REST api.
To be exactly:
The REST api does not work by using the parameter "areaOfInterest". The same works by using the parameter "exportExtent". The iOS SDK from esri just provide the parameter "areaOfInterest".
(Currently I have build a workaround by using RESTful request.)
Has anyone an idea why the "areaOfInterest" parameter won't work?
I'm using ArcMap 10.2.0.3348 to upload/publish my MapService. Could that cause the problem (that areaOfInterest seems not working)?
(My earlier question on GeoNet Help)
