excluding print formats & layout templates from print gp service
3554
06-05-2013 12:14 PM
JanicePoehlman
I'm having two issues with a print gp service:
a) I've tried removing print formats EPS and SVGZ from the print gp service by unchecking these values in the format settings of the service editor; and
b) I've tried removing 2 layout templates and MAP_ONLY by unchecking these values in the layout template settings of the service editor.
Each time I finish analyzing and publishing a .sd or saving a service definition file and publish using tools the REST endpoint/application includes the entire set  of print formats [ PDF, PNG32, PNG8, JPG, GIF, EPS, SVG, SVGZ ] and also includes every MXD in the template folder, as well as MAP_ONLY.
I can eventually remove the unneeded MXD files from the template folder, which should remove them permanently from the template list, so that's not really a long term issue.
Anyone experience the same thing?
Anyone know how I can get the service to show only the print formats I want?
Thanks.
TanuHoque
Janice,
unfortunately, these are known issues.
Currently, unchecking any formats or templates from the Service Editor dialog box has no effect.
removing template mxds from the folder is a workaround for templates. but there is no workaround for choosing a subset from the format list.
NickShoup6
Has there been a resolve to this issue yet? I am setting up a gp print service using arcgis server 10.3.1 and am seeing the same bug.
arunepuri1
1. Create new print_gp with required format with required templates.
2. In UI restrict/filter only required format and templates.
PrintTemplate (legacy) | API Reference | ArcGIS API for JavaScript
