Esri's CloudFormation templates fail to deploy on AWS
3533
6
05-02-2017 06:11 AM
NicoSteffens
New Contributor II
I've been trying to deploy one of Esri's predefined templates for AWS that are available on this website. Specifically I'm trying to deploy the "Single-machine Deployment" which seems to be one of the least complex templates.
My first approach was to do it on Windows Server 2012. I also want to use the "CloudStore" option for the storage of the portal contents. When I start the deployment everything will start up as expected. After about 40 Minutes the deployment still hasn't finished and is then rolled back (caused by a timeout I think).
After digging through the logs I found the line where it crashes - here is what it says:
FATAL: RuntimeError: arcgis_server_portal[Create Portal Site] (arcgis-server::portal line 94) had an error: RuntimeError: Cannot write to the arcgisbasedeployment-portalcontents3bucket-5swdfcafcuvf S3 bucket. Please check that the bucket exists. If access keys are used to connect to the bucket, make sure they are correct. If an IAM role is used to connect to the bucket, make sure that the IAM role has write privileges to the bucket.
It seems that the deployment needs some permissions I am not having access to. I have tried it with my account (which has access to AmazonEC2FullAccess, AmazonS3FullAccess, AmazonKinsesisFullAccess + more) and the account of my supervisor which has full administrative rights. It always fails with the error above. The bucket is created during the deployment so it has no modified access rights (or anything else) besides the manipulation that the template might do.
So I thought: "Hey, maybe it's just Windows - let's try it out on Ubuntu!"
Again I configured the template with my certificate, license files etc. and started the deployment. After about 30 minutes the server rolls back, too. It gives the following error message:
WaitCondition received failed message: 'Chef run failed. See CloudWatch log group ArcGISBaseDeployment-DeploymentLogs-1T7AJ619LV00T for details.' for uniqueId: i-082f31197199f4c84
So I go to CloudWatch and try to see the log to get further information. Unfortunately there is no LogStream available to get information from. Maybe it crashes even before the logs are created? I don't know.
My next option would be to set up an AMI only and hope to get that running on AWS. Is there any hope to get the issue resolved or is anyone else having comparable problems?
Greetings
JonathanQuinn
Esri Notable Contributor
What region are you deploying this in?  You're trying at 10.5?
NicoSteffens
New Contributor II
Hey, there! I'm trying to deploy it in EU-Central-1 (Frankfurt). The template itself is for 10.5 so this seems to be installed.
JonathanQuinn
Can you try with a region that supports Version 2, (for example eu-west-1), as outlined here:
AWS Regions and Endpoints - Amazon Web Services
NicoSteffens
New Contributor II
Yes, that works! So the problem seems to be with different versions of S3 and their availability in the different AWS Regions. Although I still get an error while configuring the Webadaptor the Deployment has been successfully completed now.
Is there any chance to get support for Version 4 so I could run it in Frankfurt (eu-central-1)? Most of my users will access it from within Germany. Ireland isn't too bad but Frankfurt would be better suited I guess.
Thanks a lot for your help,
Greetings
JonathanQuinn
This is a limitation at 10.5, unfortunately.  At 10.5.1, all of the regions listed on that page work with Cloud Formation.
TrinaChakravarty1
I am also facing the similar issue while trying to deploy in Mumbai region (ap-south-1). Getting the same error while using Cloud formation stack (from here) for single machine deployment of 10.6.1.
Any help would be appreciated.
Thanks & Regards
Trina
