Error while starting AppServer.  Required port '4000' already in use.'
4062
02-04-2014 08:52 AM
JamalNUMAN
Legendary Contributor
I tried to start a service but I got the error below:
ERROR: Failed to start the server machine 'JAMAL-SONY'. Error while starting AppServer.  Required port '4000' already in use.'
[ATTACH=CONFIG]31112[/ATTACH]
What might be the issue here?
Thank you
Best
Jamal
Jamal Numan
JamalNUMAN
http://forums.arcgis.com/threads/79058-Error-while-starting-AppServer.-Required-port-4000-already-in....
Thanks Richard,
I tried the solution provided but didn�??t work
1. Start\stop the ArcGIS Server service
2. ending the javaw.exe (I couldn�??t find it among the processes)
[ATTACH=CONFIG]31116[/ATTACH]
What other issues should I check?
Jamal Numan
RichardWatson
Jamal,
See if you can find out which process is using this port:
http://technet.microsoft.com/en-us/sysinternals/bb897437.aspx
