ERROR WHILE CREATING MAP SERVICE IN 10.0
3071
03-03-2016 04:49 AM
bharathreddy
WHILE CREATING MAP SERVICE I'M FACING FOLLOWING ERROR BELOW IS THE IMAGE ATTACHED
AdrianWelsh
MVP Honored Contributor
Can you give more details on how you were publishing this service? Also, did you click on the Analyze button before publishing the service to see about any errors prior to publishing?
bharathreddy
IM USING ARCGIS 10.0 NOTR 10.1
RebeccaStrauch__GISP
It looks to me to be a permission error to your SDE database.  Does the arcgis (or is it arcgissoc in 10.0?) have permissions required to you SDE database?  And if so, can you test your connection to it using the credentials?
ThomasColson
I'm betting you can connect to your SDE database just fine, but the ArcGIS server cannot. Try installing the ODBC drivers for your database on the ArcGIS Server, e.g., if using SQL, SQL Native Client whatever version.
bharathreddy
HELLO REBECCA
HOW TO CHECK PERMISSION WILL YOU PLEASE EXPLAIN IM NEW TO THIS
