Error registering Postgres Enterprise Geodatbase with ArcGIS Enterprise - Bad login user error
2361
03-28-2022 07:57 AM
tigerwoulds
Running ArcGIS Enterprise 10.91. I have a Postgres enterprise geodatabase connection, connected as the SDE user. In ArcGIS Pro I can create, update, and delete tables using this connection. I am attempting to register this with our ArcGIS Server so we can publish services.
Attempts to register this data store through ArcGIS Server Manager returns the following error: The connection property set was missing a required property or the property value was unrecognized. Bad login user[ ]
I would assume the username and password are correct since I can use this connection file in ArcGIS Pro. Any ideas?
ZDouiri
Hi @tigerwoulds,
Did you add the IP Address of machine ArcGIS Server in the config file of Postgresql (pg_hba.conf)?
Zakaria
ZDouiri
Hi @tigerwoulds,
Zakaria
tigerwoulds
Ah, yes. That fixed the issue. Thank you.
