Error: “Packaging succeeded, but publishing failed”,
36429
59
10-05-2014 01:21 PM
JamalNUMAN
Legendary Contributor
I couldn’t figure out why I’m getting the error below
What might be the issue here?
Thank you
Best
Jamal
Jamal Numan
JamalNUMAN
Unfortunately, I’m newly having the same error.
Very frustrating!
Do I need to spend my life stopping\starting the ArcGIS Server service to resolve this problem?
Jamal Numan
sapnas
If you change Service logon to Local System account with "Allow service to interact with desktop" option checked do you still encounter similar issue.
JamalNUMAN
Many thanks Sapna for the help,
It seems that I have no luck with any sort of settings. The problem persists to exist.
I’m encountering tough experience each time I try to publish. It is like nightmare.
What other setting might help?
Jamal Numan
sapnas
Just out of curiosity,  Did you install ArcGIS SErver in Program Files(X86)location (32 bit location) ? Normally it defaults to Program Files (64 bit location. Note some times you may get detailed error message from log files located at \arcgisserver\logs\<server name>
JamalNUMAN
Thanks Sapna,
Our ArcGIS Server has used to work fine since two years with no issues. Very recently, I’m getting that error.
Is it useful at this point to re-install it with repair mode?
Jamal Numan
JamalNUMAN
I have applied all the steps depicted in the screenshots but the problem persists to exist
What other settings\configurations still I need to check?
Jamal Numan
JamalNUMAN
cont.
Jamal Numan
KousikM
Thanks to all. Very thanks to Jamal to explain about this issue that what I need.
I have tried to restart the PublishingTools as you mentioned above. Its working for me.
Thanks lot.
GeoffreyWest
Sometimes map documents may become corrupt.  Have you tried to re-create your .MXD?
JamalNUMAN
I have created tens of new mxd files but the problem persists to exist
What is confusing me the most is:
  1. It works fine if I stop\start the ArcGIS Server service!
  2. It has used to work fine since 2 years with no single issue!
Any other suggestions?
Jamal Numan
