Error: �??Packaging failed�?� + �??the data item is inaccessible�?�,
1779
02-13-2013 09:14 AM
JamalNUMAN
Legendary Contributor
While trying to publish an mxd file, I got the message below knowing that
1. The �??ArcGIS Server Account�?� is shared to the folder containing the data (*.mdf)
2. �??ArcGIS Server Account�?� has full control on the folder containing the data (*.mdf)
3. The SDE data is registered
[ATTACH=CONFIG]21761[/ATTACH], [ATTACH=CONFIG]21762[/ATTACH]
What might be the issue then?
Thank you
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Original User: rlwatson
I don't know Jamal but you might be able to figure this out by using a tool such as SysInternals Process Monitor:
http://technet.microsoft.com/en-us/sysinternals/bb795533.aspx
The key to using this tool is setting up good filters otherwise the volume of information is overwhelming.
What you want to look for is a failed attempt to access the file system.
JamalNUMAN
Thank you Richard for the help and support,
I�??ll be contacting IT guys and see if they can resolve this issue
Best
Jamal
Jamal Numan
