ERROR EN ArcGIS WEB  APPLICATION MANAGER: Insufficent Privileges
1447
04-26-2013 03:16 PM
JULIETABERNAL
Cordial saludo amigos de ESRI.
tengo problemas al trabajar con ArcGIS web application manager para crear la interfaz de mi mapa previamente publicado en ArcServer 10.1, al hacer la autentificacion me pide un usuario: Dominio\username y una contraseña...
El problema es que puedo ingresar con cualquier dominio y usuario que ponga sin importar la contraseña y me da acceso pero no tengo privilegios  para crear una nueva aplicacion web, este es el siguiente error que me aparece:
Insufficient privileges
The current logged on user does not have administrative access to the Web server. Administrative access is required for creating and editing Web applications. Please contact your system administrator for further assistance.
no se donde tengo que definir los usuarios y las contraseñas y como puedo dar esos privilegios!
AGRADEZCO SU ATENCION Y SU AYUDA!
DerekLaw
Esri Esteemed Contributor
Hi Julieta,
This is what I got from Google Translator:
Best regards ESRI friends.
I have problems working with ArcGIS web application manager to create my map interface ArcServer 10.1 previously published, to do the authentication asks me for a user: domain \ username and password ...
The problem is that I can login with any domain user who put regardless of the password and give me access but I have no privileges to create a new web application, this is the following error that I get:
not where I have to define users and passwords and how I can give those privileges!
THANK YOUR ATTENTION AND YOUR HELP!
I am a little confused by your post. To confirm: are you using ArcGIS for Server 10.1? And you are using the Web ADF application builder? If so, please be advised that it has been deprecated and moving forward will no longer be supported by Esri.
Based on the error message, I suspect that something is incorrect with your installation. This Esri Technical Knowledge Base article can help resolve your issue,
KB #35105 - Error: Insufficient privileges - The current logged on user does not have administrative...
There is also this older support forum thread: Windows Server 2008 problems
As an alternative, I strongly recommend that you use the ArcGIS Viewer for Flex or ArcGIS Viewer for Silverlight to help you create and deploy your web mapping applications instead of the Web ADF application builder.
Hope this helps,
