Error configuring Data Store after upgrade from 10.8.1 to 10.9.1
2379
06-27-2024 05:05 PM
YiYongHuang
I am attempting an upgrade of our ArcGIS Enterprise v. 10.8.1 to 10.9.1. I receive an error the following error:
"Attempt to configure the data store failed. Caused by: Runtime error detected for one or more operations on the ArcGIS Data Store configuration store. Caused by: Failed to get file permission."
I checked the Windows credentials of the server user account, it has full permission right to the arcgisdatastore folder.
I have tried using the server name, FQDN, and  DNS with the same error.
Any help will be much appreciated.
Dan_Brumm
Does your account also have full control to the Datastore folder in C:\Program Files\ArcGIS\DataStore?
Daniel Brumm
GIS Nerd
YiYongHuang
yes, I have full permission to the folder: C:\Program Files\ArcGIS\DataStore?
YiYongHuang
I was able to resolve the issue with help from ERSI support. It turned out that Tile Cache was causing the problem. We did the following:
Completely removed Data Store
Install Data Store
Setup Datastore (Tile Cache)
Restore Rational using the command line.
Install Data Store
Setup Data store (Tile Cache)
