Enterprise DataStore Server Scripting Install
1076
05-06-2022 09:24 AM
DanielFuka
Howdy Folks!
From scratch installations of Server, Portal, and DataStore, I can not get DataStore to authenticate… I get the mean ugly bang with:
"Failed to validate the data store machine 'DATASTORE.VTUSDA.LAN'. 'Could not connect to the ArcGIS component at URL 'https://DATASTORE.VTUSDA.LAN:2443/arcgis/datastoreadmin/machines/DATASTORE.VTUSDA.LAN/validate'. The ArcGIS component on that machine may not be running or the machine may not be reachable at this time.Error: DATASTORE.VTUSDA.LAN: Name or service not known'" in the server log.
About the servers:
arcgis$ uname -a
Linux datastore … x86_64 x86_64 x86_64 GNU/Linux
arcgis$ cat /etc/issue
Ubuntu 20.04.4 LTS
To the best of my reading and following the installation documentation, I am following the documentation as best I understand, though I must be missing something. Server and Portal are installed on the same machine silently, DataStore was set up on the same network as a separate machine as Spatiotemporal. No certificates have been dealt with since this is an install on a private network. Validation also fails for a DataStore set up as relational. Setting up both, I followed the documented and error requested updates to:
datastore/framework/etc/scripts/arcgisdatastore.service
and :arcgis$ echo `sysctl vm.swappiness`,`sysctl vm.max_map_count`
vm.swappiness = 1,vm.max_map_count = 262144
arcgis$ sudo systemctl stop arcgisdatastore.service;sudo systemctl start arcgisdatastore.service;sudo systemctl status arcgisdatastore.service
arcgisdatastore.service - ArcGIS Data Store Service
    Loaded: loaded (/etc/systemd/system/arcgisdatastore.service, enabled)
    Active: active (running)
Diagnostics: tcpdump shows communication happening between the server/portal and datastore without limitation. netstat shows ports listening and connecting between the two servers.
From Server:
/home/arcgis/server/tools/createsite/createsite.sh -u siteadmin -p siteadmin12
You will be able to access ArcGIS Server Manager by navigating to
https://servport.vtusda.lan:6443/arcgis/manager
The createsite utility completed successfully.
___end From Server
From Portal:
/home/arcgis/portal/tools/createportal/createportal.sh -fn D -ln F -u siteadmin -p siteadmin12 -e [email protected] -qi 1 -qa DC -d /home/arcgis/portal/usr/arcgisportal -lf /home/arcgis/ArcGIS_Enterprise_Portal*.json
You may access the portal by navigating to:
https://SERVPORT.VTUSDA.LAN:7443/arcgis/home
The createportal utility completed successfully.
___end From Portal
/home/arcgis/datastore/tools/configuredatastore.sh servport.vtusda.lan siteadmin siteadmin12 /home/arcgis/datastore/usr/arcgisdatastore --stores spatiotemporal
Configuring data store....
Operation completed successfully.
___end From Datastore
