For future reference, if you ever mess up your self-signed certificate in ArcGIS Server 10.1 and up, here's how to set it back to the default setting:
�?��?�IF CA certificate fails
- The certificates live here .....\arcgisserver\config-store\machines\servername
- Open the server.xml and scroll down to the bottom.
- On the last line of code, you will see a keyAlias =�?�name of the certificate�?�. Since this one isn�??t working, change the alias back the original ESRI selfsigned certificate (SelfSignedCertificate).
- The code should look like this:
<Connector SSLEnabled="true" clientAuth="false" keyAlias="SelfSignedCertificate"- Stop and start the ArcGIS Server service.
