Editing fields in Map viewer fails only for a specific layer in New Map viewer.
1216
06-20-2024 07:45 AM
Yogesh_Chavan
We have a map service with feature access enabled, we are using the editable feature server in a web map.
The service does not allow us to edit fields. The same works on classic map viewer. We also can edit(add/delete) attribute values through tables in the new map viewer, and also working fine in ArcGIS Pro.
Its the edit option in map viewer that does not allow to make any changes.
Tried adding the service in a new map, it fails.
Republishing the service, works and allows us to edit. But, we would like to avoid republishing, and also overwriting as last option.
Yogesh_Chavan
Upgrade to 11.3 resolved this editing issue.
Yogesh_Chavan
