ArcGIS Powershell DSC - Multiple Service Accounts
1352
05-17-2022 09:41 PM
IhabHassan
Hi All
I have a client environment which is a multi-machine ArcGIS Enterprise deployment, and for some reason they decided to have a separate service account for each component, like Portal, Server, relational ds, spatio ds, and a GeoEvent server. So, in total, 5 service accounts.
I was hoping for using DSC to upgrade this environment to latest 10.9.1 using Esri DSC PowerShell, but what I understand from the provided guides that the DSC configuration assumes it is only one service account that can be used for all Enterprise components. In case of multiple service accounts, then I will have to use separate configuration file for each component. Am I correct in this?
I would appreciate any input.
thanks
Ihab
Regards
Ihab
SimonSchütte_ct
MVP Regular Contributor
Did you find an answer? In Github it is marked as "completed", but I could not find any information on it How do you / can you set individual service accounts for each node? · Issue #373 · Esri/arcgis-power...
