Doubts about single machine installation
1018
07-22-2019 07:19 PM
SoratoSouza_e_Silva
Hi
Could I have 2 ArcGIS Server installations or two Portal installations on the same machine? If so, how are names given both installations at the same time?
CodyMarsh
Hello Andre,
With our software it is not possible to have two instances of ArcGIS Server and Portal for ArcGIS on the same system due to the way that the software is setup. You will want two separate machines if you would like to have two instances of the software.
Here is some documentation that goes over the requirements for a Highly Available ArcGIS Enterprise which may help: https://enterprise.arcgis.com/en/portal/latest/administer/windows/configure-highly-available-system.....
- Cody
CodyMarsh
Hello Andre,
- Cody
