Disallowing “empty” value for a field without applying the “default value” option,
4442
11
02-04-2017 01:47 PM
JamalNUMAN
Legendary Contributor
For example, in the screenshot below, as a feature is digitized, its value in the “f2” field gets empty. What I wanted here is to avoid having an empty value and thus once a new feature is digitized, then the ArcMap shall ask for an entry for that feature for the “f2” field. I’m aware of that the “default value” could be a solution, however, I need the data entry to be forcibly required to choose a value from the list to avoid the empty value.
Thank you
Best
Jamal
Jamal Numan
AhmadSALEH1
Dear Jamal,
Have you tried feature templates (F.T)? if the field f2 has a number of known values lets say (v1,v2,v3) you can create 3 feature templates an each time you can assign deferent value for f2. When the user start editing your F.C he will have 3 F.T and he should select one of them to digitize the point the values of f2 will be entered directly based on what was defined in the feature template.
Ahmad
JamalNUMAN
Thanks Ahmad.
I wanted to fix this issue at the level of Desktop so that it can be inherited when the layer is published and consumed in a web mapping application. With the solution you have already proposed, I think this might not work
Jamal Numan
