Disable publishing to the root folder on Server
1398
02-23-2023 06:32 AM
MKR
Does anyone know if its currently possible to disable publishing to the root folder on federated ArcGIS Server?
Scott_Tansley
MVP Regular Contributor
There isn't an option anywhere that excludes this.  You'd need to monitor change through business process/scripting and then remove/move anything created there.
Scott Tansley
https://www.linkedin.com/in/scotttansley/
Scott_Tansley
Scott Tansley
MKR
Thanks for confirming Scott.
We have a large environment with a lot of publishers, hard to achieve through business process alone as some always seem to slip through the net. But will look at scripting something to notify us/publishers.
