Dedicated ArcGIS Server for Printing
6838
10
03-09-2017 09:42 AM
RavinHasseea1
Hi I have built 3 ArcGIS Server sites (v10.3.1), and would like to publish all the map services on 2 of the servers.
I would like to set up the third ArcGIS Server machine only for printing.
Currently we have only 1 machine in each site, and site A and site B are load balanced and have a Web Adaptor each.
Site C has not been configured yet.
Any suggestions what would be the most appropriate configuration to achieve the above and also provide scalability and best performance.
BillFox
MVP Notable Contributor
If the two sites are load balanced, maybe just consolidate them into a single virtual server with double the RAM/CPU?
Then with printing on-board too, see where performance is at before adding more pieces.
BillFox
Having multiple servers can be nice, but comes with added complexity and difficulties troubleshooting issues.
BillFox
Maybe re-purpose the second server to Portal for ArcGIS
RavinHasseea1
Thanks for the reply. We would need to have resilience, hence the 2 load balanced servers. We currently have no requirement for Portal for ArcGIS. We are implementing a Geocortex Essentials application, and it is envisaged that users will be doing fair amount of printing.
JonathanQuinn
Esri Notable Contributor
It sounds like you already have a handle on the configuration.  You can either use a siloed approach or a multi-machine site for the two machines within a single pool or cluster in your load balancer configuration which will give you scalability.  In the case of a siloed architecture, you have a bit more availability and redundancy as you don't have the single point of failure in the shared config-store at the cost of maintenance and keeping the machines synchronized.  The directories will be shared to maintain consistence behavior for the client, but if the shared directories goes down, that wouldn't necessarily cause your Server site to be completely inaccessible.  Your other machine, (which may potentially have more resources), can be configured to host printing or other GP services.  Use rules within the load balancer to send traffic to the appropriate site or machines.
JamalNUMAN
Legendary Contributor
I couldn’t figure out how to assign a particular service to a cluster?
Jamal Numan
MajdoleenO_A__Awadallah
In my case I only have the default Cluster!
JamalNUMAN
Many thanks Majdoleen for the help. It works fine
Jamal Numan
