Database on an Amazon RDS service
6634
08-23-2013 01:49 PM
TimothySaksa
I am wondering if it is workable to use an Amazon RDS server to run ArcGIS SDE from.  I have tried creating a database but I keep getting errors either saying that the username doesn�??t have permissions to perform the task or that SDE Schema and User cannot be created.
If anyone has ever tried this or can give me some feedback please let me know.
Thanks in advance.
Tim
NidhinKarthikeyan
Honored Contributor
Hi Tim,
It is not possible to run Geodatabase on Amazon RDS server. However you can run Geodatabase on Amazon EC2.
ArcGIS Server on Amazon Web Services
http://resources.arcgis.com/en/help/main/10.2/index.html#//00rq00000002000000
Geodatabases and ArcGIS Server on Amazon Web Services
http://resources.arcgis.com/en/help/main/10.2/index.html#//00rq0000003p000000
Hope this helps.
TimothySaksa
That is what i thought.  We are already running on the EC2 AMIs.  We just wanted to try and run on the managed database structure.
Thanks for the input.
Tim
JonathanBailey
Hi Tim,
At ArcGIS 10.3, you can run an enterprise geodatabase in an Amazon RDS service, but you need to do some manual configuration. See the following link:
Enterprise geodatabases in SQL Server in ArcGIS Server on Amazon Web Services—Documentation (10.3 an...
