Hi all,
I'm currently running into issues configuring data store on 10.8.1. Note that everything started when the primary (and only) relational datastore failed to validate. When running the configuredatastore tool, everything initializes and runs for a minute or so before failing with error message:
Error encountered: Machine 'https://localhost:2443/arcgis/datastoreadmin' returned an error. 'Attempt to configure data store failed
Caused by: Attempt to configure data store failed. Caused by: Attempt to configure data store failed. Caused by: Null'
Performing the same function through the browser UI produces the same result.
For some added context: Both tile cache and relational data store were installed and configured on the same machine, working great as of yesterday around 1PM. Received notification at 6PM that none of the hosted feature services are working (tile cache was), and I ended up unregistering from server with hopes of re-registering only to ultimately end up failing with a reconfigure as described above. Error messages for both restore and re-register have produced "Token Required" errors.
Anyone run into this before or have any thoughts on this?
