Data mismatch between ArcMap and ArcGIS Server 10.6.1
950
08-11-2020 09:08 AM
SrikanthHemadri
When I identify a feature which is having a double value as 0.00001 in ArcMap, it is showing what is expected. I have the layer published as a map service using ArcGIS Server. If I search for the same feature through Query Task of Map Service, I am getting the value as 9.999999999999999E-6. Below are some values where I identified such behavior.
Value in ArcMapValue in ArcGIS Server Rest Endpoint
-123.0102-123.01020000000001
-1.23456789-1.2345678900000001
0.000019.999999999999999E-6
Field Details from ArcMap:
Number Format:  Numeric
Data Type:            Double
Precision:             38
Scale:                    8
Products: ArcGIS Desktop 10.6.1, ArcGIS Server 10.6.1, Oracle DB
Srikanth
