We are working with a custom Print service created from ArcGIS Pro to allow printing of Secured service from different Servers. However, we encounter the issue when trying to print the secured services from the ArcGIS Server which on which the service is published.
We have configured the Print Service by following this "HOW TO" article and it works well with other server services.
As soon as I remove the service from that server everything work smoothly with any issues. We have tried several things, it still fails. Furthermore, if the service is created from ArcMap and then published everything works as expected.
We have also installed Print service patches for this version.
Environment details:
It would be great if I can some thoughts on this.
I'm also struggling with this issue and I'm desperate right now...
I have published secured service from ArcGIS Pro 2.9.11 to ArcGIS Server 10.9.1 (as they should be compatible) where I have also installed ArcGIS Server Map and Feature Service Security 2023 Update 1 Patch (as there this bug should be fixed), included my credentials in script and everything, but still doesn't manage to print my secured service.
Tried it as local ArcGIS Pro tool and it works fine, but after publishing it as geoprocessing tool to my server I get common error: Failed to create layer from service at https://.../arcgis/rest/services/.../MapServer
Is there anything else I can do about it?
Hey Stefan,
I would recommend raising a Support Case with your Esri distributor for assistance, as print cases can be fairly tricky.
I would recommend checking other patches that are available, as there are some print specific patches for 10.9.1 such as the following which may assist.
For testing I would also ensure that your Web Map just contains a basemap and layers that are stored on the default datastore, as this can rule out a lot of permission errors that can arise when the ArcGIS Server account doesn't have internet access.
Hope that helps,
David
Hi David,
Thank you for your answer. Mentioned patch has also been already installed and it doesn't seem to help as problem still persists.
I'm testing print service with basemap and two services with data in Enterprise database, one secured and other one not. As I mentioned, services are printing fine while using tool in Toolbox. After publishing and running GP tool I'm getting Error although I'm using the same WebMapJson, but even if I unlock services and update WebMapJson to print unsecured services, I'm not getting the Error but services don't get printed.
If anyone has other advice, I'll be looking forward to try with it.
Hello @StefanStamenković ,
Hope you are keeping safe and well. Could you please share more details mentioned below:
Additionally, could you share a snippet of the .py file you have generated and published.
Hope it helps!
-Archit
Sorry for delayed answer.
Please find below content of my .py file.
import sys
import os
import arcpy
import uuid
# constants
SERVER_PROD_NAME = 'Server'
PRO_PROD_NAME = 'ArcGISPro'
PAGX_FILE_EXT = "pagx"
MAP_ONLY = 'map_only'
# Specify credentials for secured services in the WebMap JSON
secure_server_connections = [r'path\to\ags\file.ags']
# Import credentials
importedConnections = arcpy.ImportCredentials(secure_server_connections)
# default location and current product name
_defTmpltFolder = os.path.join(arcpy.GetInstallInfo()['InstallDir'], r"Resources\ArcToolBox\Templates\ExportWebMapTemplates")
_prodName = arcpy.GetInstallInfo()['ProductName']
_isMapOnly = False
# export only map without any layout elements
def exportMap(result, outfile, outFormat):
mapView = result.ArcGISProject.listMaps()[0].defaultView
w = result.outputSizeWidth
h = result.outputSizeHeight
dpi = int(result.DPI) #a workaround for now for a bug
try:
if outFormat == "png8" or outFormat == "png32":
if (outFormat == "png8"):
colorMode = "8-BIT_ADAPTIVE_PALETTE"
else:
colorMode = "32-BIT_WITH_ALPHA"
mapView.exportToPNG(outfile, w, h, dpi, None, colorMode)
elif outFormat == "pdf":
mapView.exportToPDF(outfile, w, h, dpi)
elif outFormat == "jpg":
mapView.exportToJPEG(outfile, w, h, dpi, None, '24-BIT_TRUE_COLOR', 100)
elif outFormat == "gif":
mapView.exportToGIF(outfile, w, h, dpi)
elif outFormat == "eps":
mapView.exportToEPS(outfile, w, h, dpi)
elif outFormat == "svg":
mapView.exportToSVG(outfile, w, h, dpi, False)
elif outFormat == "svgz":
mapView.exportToSVG(outfile, w, h, dpi, True)
elif outFormat == "aix":
mapView.exportToAIX(outfile, w, h, dpi)
elif outFormat == "tiff":
mapView.exportToTIFF(outfile, w, h, dpi, False, "32-BIT_WITH_ALPHA", "DEFLATE", True) #return geoTIFF_tags
except Exception as err:
arcpy.AddError("error raised..." + str(err))
raise
# export layout
def exportLayout(result, outfile, outFormat):
layout = result.ArcGISProject.listLayouts()[0]
dpi = result.DPI
try:
else:
layout.exportToPNG(outfile, dpi, colorMode)
layout.exportToPDF(outfile, dpi)
layout.exportToJPEG(outfile, dpi)
layout.exportToGIF(outfile, dpi)
layout.exportToEPS(outfile, dpi)
layout.exportToSVG(outfile, dpi, False)
layout.exportToSVG(outfile, dpi, True)
layout.exportToAIX(outfile, dpi)
layout.exportToTIFF(outfile, dpi, "32-BIT_WITH_ALPHA", "DEFLATE")
raise
# generating a unique name for each output file
def generateUniqueFileName(outFormat):
guid = str(uuid.uuid1())
fileName = ""
fileExt = outFormat
#changing the file extension for few instances
fileExt = "png"
fileExt = "tif"
fileName = '{}.{}'.format(guid, fileExt)
fullFileName = os.path.join(arcpy.env.scratchFolder, fileName)
return fullFileName
# Main module
def main():
# Get the value of the input parameter
WebMap_as_JSON = arcpy.GetParameterAsText(0)
outfilename = arcpy.GetParameterAsText(1)
format = arcpy.GetParameterAsText(2).lower()
layoutTemplatesFolder = arcpy.GetParameterAsText(3).strip()
layoutTemplate = arcpy.GetParameterAsText(4).lower()
if (layoutTemplate.lower() == MAP_ONLY):
_isMapOnly = True
layoutTemplate = None
else:
_isMapOnly = False
# Special logic while being executed in ArcGIS Pro
# - so that a Geoprocessing result can be acquired without needing any json to begin to feed in
# - this is to make the publishing experience easier
if (WebMap_as_JSON.replace(' ', '') == '#'):
WebMap_as_JSON = '#'
if (_prodName == PRO_PROD_NAME):
return
elif (_prodName == SERVER_PROD_NAME):
arcpy.AddIDMessage('ERROR', 590, 'WebMap_as_JSON')
else:
arcpy.AddIDMessage('ERROR', 120004, _prodName)
# generate a new output filename when the output_filename parameter is empty or the script is running on server
if outfilename.isspace() or _prodName == SERVER_PROD_NAME:
outfilename = generateUniqueFileName(format)
# constructing the full path for the layout file (.pagx)
if not _isMapOnly:
# use the default location when Layout_Templates_Folder parameter is not set
tmpltFolder = _defTmpltFolder if not layoutTemplatesFolder else layoutTemplatesFolder
layoutTemplate = os.path.join(tmpltFolder, '{}.{}'.format(layoutTemplate, PAGX_FILE_EXT))
#Convert the webmap to a map document
try:
result = arcpy.mp.ConvertWebMapToArcGISProject(WebMap_as_JSON, layoutTemplate)
#Export...
if (_isMapOnly):
if (result.outputSizeWidth == 0) or (result.outputSizeHeight == 0):
arcpy.AddIDMessage('ERROR', 1305)
exportMap(result, outfilename, format)
else:
exportLayout(result, outfilename, format)
# Clear credentials
arcpy.ClearCredentials(importedConnections)
arcpy.AddError(str(err))
# Set output parameter
arcpy.SetParameterAsText(1, outfilename)
if __name__ == "__main__":
main()
Thank you in advance!
Thanks for sharing the details. While I analyze the script you have shared as it seems a bit modified than usual. I would like to bring the following to attention and consideration:
Here are some initial tests I ran:
Changes Made in the script (very-initial) (attached updated):
Additionally, I think "Web-Tier Authentication" could be the culprit here, Can you check this post about ArcGIS Server Windows Service account with IWA.
It would be great if you can try the attached script, publish it as geoprocessing service, Set the logging level for Geoprocessing service and try to run the tool and what happens.
Hope it helps!
-Archit
