Create Feature Class and Attachments
1709
09-04-2014 12:38 PM
jaykapalczynski
Honored Contributor
Trying to create a FC in my SDE database and add ability for attachments.
I create the FDS and then a point FC and then right click ... Manage>Create Attachments  is disabled....
What gives.....am I doing it wrong?  I am using Advanced license.
jaykapalczynski
Honored Contributor
Embarassed.....permissions were too low on the connect to the DB.  Used my Admin privileges and it worked fine.
AsrujitSengupta
Which version of ArcGIS Desktop are you using?
What is the version of the sde geodatabase?
Attachments were not supported in 9.3 geodatabases, so you need a 10.x geodatabase. The 'Create attachment' option in a feature class is not available for any pre ArcSDE 10 geodatabase.
jaykapalczynski
Honored Contributor
