Create Enterprise Geodatabase hangs at 9%
4107
01-10-2020 06:56 AM
PeterLee3
The tool Create Enterprise Geodatabase hangs at 9%, right after logging: "Created geodatabase tables and stored procedures." It hangs in both Pro 2.4 and ArcMap 10.7.1
Platform: Windows Server 2016
Database: Oracle 19c
I attached screenshots.
How do I get the tool to work?
-Peter
George_Thompson
Esri Notable Contributor
Have you installed the Oracle 19c Patch (for ArcMap 10.7.1): ArcGIS (Desktop, Engine, Server) Support for Oracle 19c Patch
You must also be at ArcGIS Pro 2.4.2; Oracle database requirements for ArcGIS 10.7.x and ArcGIS Pro 2.3 and 2.4—System Requirements | Docu...
If so, how long has it been at 9%?
--- George T.
PeterLee3
George,
Yes I installed the 19c patch.
Install order:
ArcGIS Desktop 10.7.1.11595
Oracle 19c patch
ArcGIS Pro 2.4.0.19948
ArcGIS Pro hung for 40 minutes before I killed it.
I reverted the VM, then ran it in ArcMap, and I let it run overnight and it hung for 15 hours.
I'll check my.esri.com to see if I can download a newer ArcGIS Pro.
-Pete
George_Thompson
Is your installation local (in the same location) as the Oracle DB?
Does the the user being used in the GP tool have all the correct permissions?
You may want to open a technical support case for this not completing so an analyst can take a look.
--- George T.
PeterLee3
Yes.
Yes, the Oracle user is the sysdba.
I'll try using the latest patch for ArcGIS Pro like you suggested. If it fails, I'll open a ticket.
Thanks for the suggestions.
-Pete
PeterLee3
I contacted Esri support. They were not able to reproduce the situation.
I reverted to Oracle 18c and used ArcGIS Pro 2.4.3. I was able to successfully create an enterprise geodatabase.
-Peter
