Changes to coded values could not be saved in ArcMap while I see them saved in Pro
2150
05-28-2021 12:40 PM
MaximeDemers
Im facing a weird problem with coded values. Im trying to change the description inside a domain in ArcMap. I can save it without any error, but when I close and re-open ArcMap, I see the change was not saved.
However, if I inspect the same domain in Pro, I see the changes in the description just  as I had modified them in ArcMap.
Here is some of the specifications of our installations:
ArcMap 10.6.1
Pro 2.7.1
SQLServer 2012 on Windows Server 2012R2
Any idea what could be tried to resolve this?
JoeBorgione
Stop using ArcMap and use ArcGIS Pro only?  Just a thought!
All seriousness aside; what happens if you restart your computer and then fire up ArcMap?
MaximeDemers
Thank you, but we cannot stop using ArcMap for some projetcs right now. I did try to reboot ArcMap and SQLServer as well without success
JoeBorgione
That is really odd.  What if you make the change in Pro?  Does ArcMap see them?
I don't have ArcMap installed or I would try to replicate the problem.
George_Thompson
Esri Notable Contributor
So part of the issue may be that SQL Server 2012 is supported with ArcMap 10.6.x but not with ArcGIS Pro 2.7.x. : https://desktop.arcgis.com/en/system-requirements/latest/database-requirements-sqlserver.htm
Though I find it weird that you can see everything in Pro with no issues.
What is the version of the Enterprise Geodatabase being used?
--- George T.
