change virtualoutput
1425
10-10-2012 04:41 AM
anjelinaponker
Hi
How can I change virtualoutput in ArcGIS Server 10.1? in ArcGIS server 10 it was easy.
Regards
MLowry
Pretty sure that was in the post-install, which means probably baked into a config text file somewhere now.
anjelinaponker
Hi
i,m using Arc GIS Server 10.1 and I did not see any setting for virtual output directory like arcgis job and ...
plese help me.
RandallWilliams
This can be done in ArcCatalog or the ArcGIS Server admin API, but I believe that there is a bug with making this change using ArcCatalog.
NIM085533: Changing the output directory for a service in ArcCatalog does not change the virtual directory of the service
