Hello everyone,
I'm standing up an isolated environment for a client's ArcGIS Enterprise upgrade (10.9.1 → 11.5), built fresh on AWS rather than upgraded in place. The goal is to validate workflows before cutting over to production.
The new environment will run at https://gistest.company.com/portal so I can test publishing, Experience Builder apps, traditional versioning with two-way replication, and a set of Esri hardening and IIS security changes. Once testing is complete, I need to point the URL back to https://gis.company.com/portal.
The blocker: a host-file edit won't work here since these workflows need to hit the real internal ArcGIS Enterprise environment. I also can't update the license file on my.esri to reflect the test URL — if I delete the existing portal license and generate a new one for gistest.company.com, I then can't reach the portal to apply it, since the portal URL and license URL are out of sync.
I found Esri's doc on updating the organization URL (link below), but it's light on detail, and I'm not sure whether following it risks breaking federation with the rest of the site (Server, hosting, etc.):
Update the organization URL — Portal for ArcGIS | ArcGIS Enterprise 11.5 docs
https://enterprise.arcgis.com/en/portal/11.5/administer/windows/update-the-organization-url.htm
Has anyone gone through this URL swap (test → prod naming) on 11.5 without breaking federation, or found a cleaner way to license a temporary environment for this kind of side-by-side testing?
Lavanya
Hello @LavanyaVasudevanNES
I have not done this exact 10.9.1 to 11.5 side-by-side URL swap recently, but a few things stand out from the 11.5 documentation.
First, I would be very careful with the Update organization URL workflow at 11.5. The documentation currently has a caution that this workflow is impacted by a defect and requires a patch before proceeding:
Update the organization URL—Portal for ArcGIS | Documentation for ArcGIS Enterprise
So I would definitely confirm that patch is installed before testing this workflow.
The second thing is that this does not look like a simple Portal URL change only. From the documentation, the workflow updates URLs across the Enterprise organization, including:
So if you go from:
to:
I would expect the federated Server URLs to need the same careful handling as well, not just Portal.
A few things I would check or plan for before doing the swap:
For the licensing part, I would be cautious about deleting or regenerating anything tied to the current production environment in My Esri. Since this is a temporary side-by-side environment that will later take the production URL, I would probably confirm the safest licensing approach with Esri Licensing or Support before changing the production portal license allocation.
My understanding is that one possible path is to license the isolated test environment with the temporary URL, validate the workflows, then at cutover follow the organization URL update workflow and import the correct license file for the final URL. But because this involves the production organization URL and licensing, I would want Esri to confirm the exact sequence.
After the URL change, I would test more than just whether Portal opens. I would check:
So I think the workflow is possible based on the documentation, but I would treat it as a full Enterprise URL migration, not just a Portal setting change. The 11.5 patch requirement, federated server URL order, WebContextURL, certificates, licensing, and app/service validation would be the main areas I would be careful with.
