When i Trying to register Relational Datastore is give me these Error
Can not register Relational datastore
@AhmedTarek123 This is a connection time out issue - please check for the obvious like content directory path, URL and folder permissions. Also looks like you are trying to have an HA setup - what is the ArcGIS version? Check references below:
https://enterprise.arcgis.com/en/data-store/latest/install/windows/overview-data-store-setup.htm
https://enterprise.arcgis.com/en/data-store/latest/install/windows/add-standby-machine.htm
Hello @AhmedTarek123
It seems like when the configuration wizard is trying to reach the internal Database, it is unable to achieve a response in designed time.
I would suggest having a look at the following documentation and running a check for these on the Data Store machines (in your scenario Relational Data Store):
Ports used by ArcGIS Data Store
Mostly, as per my understanding it could be 9876 port:
Furthermore, I would recommend adding an exception to Windows Firewall as disabling the Firewall would a tricky situation with IT team.
This explains those steps in details : Adding Windows Firewall Exceptions
Hope it helps!
-Archit
Greetings @AhmedTarek123
When configuring the Data Store through the Wizard as per the image you supplied, I would recommend trying to use the FQDN of the server instead of "localhost". For instance, if this is a base deployment (all components in the same machine, try https://lp-3-3-31.esri.local:2443/arcgis/datastore.
Hope that helps.
