CAN NOT REGISTER ORACLE DATABASE IN ANOTHER DOMAIN
879
02-25-2013 12:57 PM
troyturcott
Hello Everyone,
I can't seem to get ArcGIS Server to register a .sde, direct connection to an Oracle database in a domain that's not the same as the one my ArcGIS server is a member. This .sde connection works fine within ArcCatalog, but no-worky from ArcGIS Server - Is this the same kind of issue with ArcGIS Server security not being able to query active directory outside its own domain (that is a known issue)? I was told/emailed by support that this issue with Active Directory would be solved with Service Pack 2 - well, it's time for that bit of software to hit the street - any thoughts, ESRI?
Frustrated...
RichardWatson
I am not ESRI but my understanding is that SP2 was scheduled for March but has been cancelled and replaced by 10.2 which is scheduled for June.  My best guess is that you should plan for July.
adrianakbari
I am experiencing the same issue...
