We've had a 10.2 AGS implementation for a good year+ and just the other day I attempted to repath the "jobs" folder to a new shared location. Got an error and had to revert. I also tried to publish to our 10.2 server from a 10.3 MXD. In any event, after those couple things, I've not been able to publish anything to that 10.2 cluster.
In the MXD I can "share as" then the initial dialog comes up asking where I want to publish... I choose the AGS server I want... then it asks for a folder. I enter that. Then, that dialog goes away and a new publish dialog should appear. The one with the parameters, pooling, capabilities, etc... That never comes up. I just get a "waiting icon" and that's that. No AGS log entries, no event viewer entries, no nothing. Just a spinning cursor.
What can I do to troubleshoot or fix this. Also, most likely the same issue, but we have a test 10.3 AGS cluster as well, which has been working great. Yet again however, the other day a coworker tried to publish a map service to that from a 10.2.2 Arcmap. Now, whenever anyone tries to publish to that cluster, 10.3 Desktop or otherwise, we just get a spinning "waiting" cursor in Arcmap, as described above.
So, both our production and test servers are FUBAR'd. Any advice would be very welcome.
Solved! Go to Solution.
Ok, I've got the solution. I re-added the new "jobs" folder location back in and re-pointed the publishing service to that new jobs folder. Bammo, back in commission!!!
I did find this thread, which states that publishing from 10.2 to 10.3 AGS shouldn't be a problem. I'm totally baffled. Can ArcMap 10.2 clients publish to ArcGIS Server 10.3
