Can I publish a vector tile package WITHOUT using Portal or AGOL?
3598
03-07-2022 11:42 AM
berniejconnors
Can I publish a vector tile package WITHOUT using Portal or AGOL?  Or is the use of one or the other required?
We currently run ArcGIS Server 10.7.1 but we have not deployed Portal.
Bernie.
Tags (3)
2 Solutions
Scott_Tansley
MVP Regular Contributor
You need an AGOL or ArcGIS Base Deployment.  Portal and Hosting Server ( with ArcGIS Data Store)
Scott Tansley
https://www.linkedin.com/in/scotttansley/
Scott_Tansley
It’s because it fits into the Web GIS model.  The supporting APIs come from the Enterprise.  Only the more traditional services, Map, Image, geoproc, geocode are supported by a standalone server and the APIs available to it.
Scott Tansley
Scott_Tansley
Scott Tansley
berniejconnors
10-4.  Thanks @Scott_Tansley  for confirming what I suspected.
Bernie.
Scott_Tansley
Scott Tansley
berniejconnors
Scott,
        I presume the same publishing model also applies to web scenes.  Is that correct?
Bernie.
Scott_Tansley
Yes Bernie.
Scott Tansley
