Big difference between REST and Geoprocessor query performance
870
06-17-2014 11:36 AM
DaveHighness
I've written an application for bench marking and tracking performance of ArcGIS Server. As part of the app it does a Javascript API Query Task of a feature layer though the REST and later runs the Select By Attribute GP tool from a Geoprocessing Task. This is the same SDE feature class with about 1.34 million polygons, it has both spatial and attribute indexes in place. The query runs in about 1 second from the REST but takes 1 1/2 minutes from the GP Tool. What is up with that?
The SDE feature class is in PostgreSQL SDE 10.2.2
ArcGIS Server 10.2.2
Windows 2008 r2
The definition query and rendering performance is great! GP is really slow!
Dave
nicogis
MVP Alum
it is not exactly the same thing:
1) One drawback of geoprocessing services is that they have a relatively large memory footprint and may run slower.
2) Select by attributes stores the selection so if you have many rows in result of query, the result is stored in a table
