Best Practice to promote Webmap across environments
1194
11-20-2024 08:28 AM
DRae
We have two environments for ArcGIS Enterprise. One is Production and One is Staging. We usually deploy the webmap/feature layer from ArcGIS to Staging first, and then to the production. However, the item id will be different across the environments. What is the best practice to do the promotion such as that? Also can we make sure the item id will stay the same across the different environment?
simoxu
by MVP Alum
It really depends on your environment architecture and the nature of the services, are they hosted or referenced? are they sharing the same geodatabase, etc.
in terms of preserving the itemid, yes you can preserve the item id when you are cloning the items.
see details here:
https://developers.arcgis.com/python/latest/api-reference/arcgis.gis.toc.html#arcgis.gis.ContentMana...
TimoT
simoxu
by MVP Alum
ah.. just remember @JakeSkinner  had a great post about migrating content from one environment to another, please check it out:
https://community.esri.com/t5/arcgis-enterprise-documents/migrate-content-for-arcgis-enterprise-arcg...
