ArcSOC excessive memory usage?
2874
02-26-2016 11:52 AM
LeoLadefian4
I'm looking at one of my processes and can't seem to figure out which service this is associated with.  The only reference to it is in the  server error file:
Perhaps this is a critical process for server that I'm not aware of.  Any ideas? This is Server 10.1.
Tags (1)
MichaelVolz
Esteemed Contributor
You might be able to get to this information in Task Manager under Processes and Command Line.  At least this is what I can do on a Windows 2008 Server.  Not sure if this functionality was available back in 10.1, but you can give it a shot to track down the service.
JakeSkinner
Esri Esteemed Contributor
Hi Leo,
I can't recall at 10.1, but do you have a 'Columns' button within the Logs tab?  You can check the 'Source' option:
Then, if you set the Log Filter to 'Fine' or 'Verbose', you should be able to see which service is related to the Process.  The below screen shot is showing the source to be the 'Airports' service:
