Arcgis Webadaptor
1411
10-19-2016 03:22 AM
AdeoyeOyedeji
Error 1722: there is a problem with this windows installer package.
A program run as part of the setup did not finish as expected.
Contact your support personnel or package vendor. Action
APPHOST_ANONYMOUSAUTH, location: ....\appcmd set config
"DefaultWebsite/arcgis/apps/dashboard-win"
-section:system.webserver/security/authentication/anonymousA...
Anybody with idea to resolve this challenge?
I Installed the same Webadaptor on another machine and was installed.
Please kindly help.
JonathanQuinn
Esri Notable Contributor
If you try to install it via command line, or look at the Event Viewer, can you see the full error message?  Did you let the web adaptor install IIS for you?
