ArcGIS Web Adaptor 10.9.1: Configuring the Web Adaptor ends up with token and access issue,
1382
06-13-2022 11:33 AM
JamalNUMAN
Legendary Contributor
I couldn’t figure out why configuring the Web Adaptor ends up with token and access issue as per the screenshots below
"Failed to get administrator token from the server. Please verify that the specified server can be successfully accessed."
Jamal Numan
JonEmch
Hello Jamal,
   I would strongly encourage you to use the DNS / machine name to configure the WA, not the IP.
Keep on keeping on!
JamalNUMAN
The issue here is not the machine name, localhost or IP. It appears to be related to https\http issues.
It should work with:
http://jamalnuman2/adaptor/webadaptor/server
but not with https:
https://jamalnuman2/adaptor/webadaptor/server
despite the fact that the services directory works with both http and https
http://jamalnuman2:6080/arcgis/rest/services
https://jamalnuman2:6443/arcgis/rest/services
Clip_749.jpgClip_749.jpgClip_750.jpgClip_750.jpgClip_751.jpgClip_751.jpgClip_752.jpgClip_752.jpgClip_753.jpgClip_753.jpg
Jamal Numan
