ArcGIS Server Software Authorization Wizard Required esri domains through Firewall
4250
07-12-2023 02:24 AM
Arun_PrasadRamanujadoss
ArcGIS Enterprise version: 10.9.1
I am trying to authorize the ArcGIS Server that I have installed using the License Provisioning file shared. My system is disconnected and I have asked the network administrator to provide access to domain service.esri.com(198.102.61.207). But still I am getting "Internet connection error".
Can anyone please list the domains that have to be allowed through firewall to complete authorization?
Please note it is not possible to get open internet access to the server in my organization.
Arun_PrasadRamanujadoss_0-1689153698158.pngArun_PrasadRamanujadoss_0-1689153698158.png
@MarceloMarques Thanks I have used Wireshark to do the same and I couldn't find any ip apart from sevice.esri.com(198.102.61.207) relevant to this. As @ChrisUnderwood  suggested I went for the same offline method with a small change to avoid email goint out:
1. Generated the "authorize.txt" file
2. Logged in to the myesri.com with any organization account
3. Opened the "https://my.esri.com/#/licensing/activations/secure-site" web page
4. uploaded the authorize.txt file
5. Generated the "authorization.ecp" file
6. Copied to the Server and opened it using "Sofware Authorization Wizard"
7. Click OK
The above method helped me.
Thanks a lot.
ChrisUnderwood
Hello @Arun_PrasadRamanujadoss , would using the licensing option "Authorise by email", allow you to bypass your Firewall and Internet access restrictions ?
https://enterprise.arcgis.com/en/server/10.9.1/install/windows/authorize-arcgis-server.htm
Thanks @ChrisUnderwood , I didn't want to go through this method as the license file will go to a another department and I have to do it on multiple servers. The licensing department is suggesting to go with internet way, as it is simpler. And our network team needs the exact domain that are required to open them.
MarceloMarques
@ChrisUnderwood - if you install Fiddler on your server then you can turn on Fiddler to capture all network traffic, then when you execute the Software Authorization you will capture exactly what is been blocked. I hope this helps.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
7. Click OK
Thanks a lot.
