arcGIS Server Setup Wizard - Create New Site Error
6755
6
12-14-2012 11:12 AM
AaronHeyman
I am doing a new install and I keep getting the following error when I try and create the site.  Using all defaults.  Does anyone have any idea what this is about?
failed to register the activation group
Thanks in advance
BubbaHey
I haven't seen that one.  Wonder if it is license related?  Try renaming the keycodes file which is usually in C:\Program Files\Esri\License10.1\sysgen\keycodes then run Software Authorization again and try to create a site again.
MuryadiOey
Bubba is right. it is usually related to License. I am wondering in next SP ESRI could fix the error message to more specific on the error.
SchoppMatthieu
I just had the same problem,
The software authorization has been successfully activated. I re-ran it several times with the same result.
Installation on Windows 7.
I finally sorted it by restarting the computer. I also used IE instead of Chrome for the site creation but I don't think it matters.
oliverng
My version is 10.2. I have my problem solved after I enable the internet connection of my server
SerjStolyarov1
This error can occur when user has multiple licence codes inside the "keycodes" file which is located usually in C:\Program Files\ESRI\License10.5\sysgen\keycodes
- Manually deleting the wrong version codes from the keycodes file should fix the issue.
- Alternatively, deleting the keycodes file and running "Software Authorization for ArcGIS Server" tool again will generate a new file with the correct keys.
Make sure to restart ArcGIS Server service after amending or re-authorizing for the changes to take effect.
PanagiotisPapadopoulos
In my case Serj's comment fix my problem.
