Are you using Web Adaptor? If so, in II Manager, check Authentication - it should be set to Windows and Anonymous disabled.
IS SSL functioning? Are you using self-signed or CA certificates?
I am an ArcGIS Server Administrator. I have the same issue. I am worried about our ArcGIS Server Security. Did you figure out why the WARNING appears? Thanks!
-YL
