ArcGIS Server raising "Error in checking static data" for deleted services
300
3 weeks ago
WilliamHarperAppDev
We just upgraded a standalone ArcGIS Server instance from 11.3 to 11.5 and it started raising hundreds of warnings "Error in checking static data for service: xyzxyzx - Service not found." In some cases it's raising 15 warnings every minute, but in all it's flushing out our logs and consuming memory resources. Typically it will spend ~ 1 hour logging these messages and simply stop. The thing is, these are all old services that have been deleted. I've verified that none of the server directories have orphaned entries. Preceding many of these incidents, Server will log a message "checking for expired items in D:\arcgisserver\directories\arcgisoutput" or "checking for expired items in D:\arcgisserver\directories\arcgissystem\arcgisuploads."
This behavior first arose following an in-place upgrade from 11.3 to 11.5 and we noticed this before I applied any Server security patches (but subsequent application has not improved that behavior). The machine is running in Windows Server 2022 Datacenter, IIS Web Adaptor, and alongside a PostgreSQL 16.8 EGDB. This instance of Server is not federated with any Portal. A similar upgrade to a dev ArcGIS Server instance has not raised the same warnings.
WilliamHarperAppDev
I commented in this thread that these issues seem similar, but ours arose prior to applying the Security 2026 Update 2 patch: https://community.esri.com/t5/arcgis-enterprise-questions/portal-for-arcgis-security-2026-update-2-p...
Priya_Das
Hi @WilliamHarperAppDev
Did you checked the following directory to confirm if the old service folders still exists or not
Additionally, Check for Orphaned Configuration Files in D:\arcgisserver\config-store\services, ensure there are no leftover .json files for deleted services.
If you find any, back them up and then remove them.
WilliamHarperAppDev
As I mentioned in my post we did verify that there are no folders for these old services anywhere in D:\arcgisserver\... . My assumption is that there is internal content elsewhere triggering these warnings, but whether it's readable/editable as plaintext I don't know. I also verified that a robots.txt is in place at the IIS root to dissuade web crawlers from hitting endpoints for old services.
RobertMartinez
We are experiencing the same issue after upgrading ArcGIS Enterprise from 11.3 to 11.5. The server logs show "Error in checking static data for service:" for map services that were already deleted in our Portal and we are not seeing any orphaned entries, either. We ended up adding more RAM to both our machines hosting ArcGIS Server to handle the spikes in memory caused by this issue.
MattiasEkström
I'm seeing thoose warnings in our log as well, we also have ArcGIS Enterprise 11.5 that was uppgraded from 11.3. It was a pretty long time ago though, but I'm not sure when thoose warnings started to occure.
