ArcGIS Server Printing Tool
5727
10-22-2015 02:46 AM
DEVAPP
Hi at all.
I have develop a web application Javascript that use the ArcGIS Server Printing Tool for print a map.
My ArcGIS Server are deploy into a back end server and web app on front end server.
The back end have the open the comunication with arcgis online on internet.
When i try to print using tool the function crash and the log of server is this:
Last Write Time:        14/10/2015 10:51:58
Process Name:   ArcSOC.exe : E:\Program Files\ArcGIS\Server\bin\ArcSOC.exe
Process Architecture:   x64
Exception Code: 0xC0000005
Exception Information:  The thread tried to read from or write to a virtual address for which it does not have the appropriate access.
Heap Information:       Not Present
Any help please?
thanks
Tags (1)
ChrisSmith7
Honored Contributor
Can you try just hitting it through the service URL with some test data? E.g.
Here's the JSON string I'm using:
  "mapOptions" : {
  "showAttribution" : true,
  "extent" : {
  "xmin" : -9580490.966797964,
  "ymin" : 4540188.193338305,
  "xmax" : -9493658.502665972,
  "ymax" : 4678080.592364816,
  "spatialReference" : {
  "wkid" : 102100
  "wkid" : 102100
  "scale" : 577790.5542889922
  "operationalLayers" : [{
  "id" : "World_Ocean_Base_5811",
  "title" : "World_Ocean_Base_5811",
  "opacity" : 1,
  "minScale" : 591657527.591555,
  "maxScale" : 9027.977411,
  "url" : "http://services.arcgisonline.com/arcgis/rest/services/Ocean/World_Ocean_Base/MapServer"
  "id" : "LOJIC_LandRecords_Louisville_3326",
  "title" : "LOJIC_LandRecords_Louisville",
  "opacity" : 0.24,
  "minScale" : 0,
  "maxScale" : 0,
  "url" : "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_LandRecords_Louisville/M...",
  "visibleLayers" : [0, 2]
  "id" : "World_Ocean_Reference_1604",
  "title" : "World_Ocean_Reference_1604",
  "opacity" : 1,
  "url" : "http://services.arcgisonline.com/arcgis/rest/services/Ocean/World_Ocean_Reference/MapServer"
  "id" : "map_graphics",
  "opacity" : 1,
  "minScale" : 0,
  "maxScale" : 0,
  "featureCollection" : {
  "layers" : []
  "exportOptions" : {
  "outputSize" : [800, 1100],
  "dpi" : 96
  "layoutOptions" : {
  "titleText" : "Louisville – Land Records, Landscape PDF",
  "scaleBarOptions" : {
  "metricUnit" : "esriKilometers",
  "metricLabel" : "km",
  "nonMetricUnit" : "esriMiles",
  "nonMetricLabel" : "mi"
  "legendOptions" : {
  "operationalLayers" : []
This should output something like:
 "results": [
  "paramName": "Output_File",
  "dataType": "GPDataFile",
  "value": {
  "url": "https://yourGIS.server.com/arcgis/rest/directories/arcgisoutput/Utilities/PrintingTools_GPServer/_ag..."
 "messages": [
Which would be the output of your file. This should let you debug more easily - let me know what happens!
ChrisSmith7
Honored Contributor
What version of ArcGIS Server are you using?
There's quite a few reasons this could happen - basically, it's trying to access something it shouldn't (buffer overrun). Did you install on a clean machine - were there any other versions of ArcGIS on the machine before? Did you, by chance, install/update antivirus software recently?
DEVAPP
Hi Chris,
the server have ArcGIS Server 10.2.2. We have open a comunication with REST folder AGOL. The AGS are istalled on a clean machine. The server have a McAfee enterprise and Antispyware Enterprise.
ChrisSmith7
Honored Contributor
  "mapOptions" : {
  "extent" : {
  "wkid" : 102100
  "wkid" : 102100
  "opacity" : 1,
  "opacity" : 0.24,
  "minScale" : 0,
  "maxScale" : 0,
  "opacity" : 1,
  "opacity" : 1,
  "minScale" : 0,
  "maxScale" : 0,
  "layers" : []
  "exportOptions" : {
  "dpi" : 96
  "layoutOptions" : {
  "legendOptions" : {
 "results": [
  "value": {
 "messages": [
