ArcGIS Server Manager no open
1430
07-13-2019 04:45 PM
SoratoSouza_e_Silva
My ArcGIS Server manager it does not open anymore. The only print loading in my screen is below:
I was restart the services but no work properly. What can I to do for solve this problem?
Thank´s
Tags (1)
HarroldSompotan
Hello @André,
Can you please share with us your current configuration of this Arcgis Server? is it Federated? or Stand alone Arcgis Server? Newly created site or an existing site?
In the meantime, I would recommend trying to access the site via port 6080, or the full Machine name,
with the combination of HTTPS:  examples:
http://localhost:6080/arcgis/manager or http://FQDN:6080/arcgis/manager http://localhost:6080/arcgis/manager
http://localhost:6080/arcgis/rest or https://localhost:6443/arcgis/rest
http://localhost:6080/arcgis/admin or https://localhost:6443/arcgis/admin
JonathanQuinn
Esri Notable Contributor
If you've federated Portal and Server, you can only reach Server Manager using either the services or admin URL you used in federation:
https://enterprise.arcgis.com/en/portal/latest/administer/windows/configure-highly-available-system....
