ArcGIS Server Manager Error Message
5489
11
12-14-2022 06:54 AM
JD1016
Hello,
I checked our ArcGIS Server Manager logs and noticed the following error message (see attached).
Anyone understand what this is trying to indicate or the resolution?
Everything seems to be running fine.
Thank you.
Jeff
berniejconnors
Unfortunately the error code definitions for 9001 and 9003 don't give any more info than what is displayed in the log "Mesage" column.  You may want to try and match these errors by date and time with the web logs on your web adaptors.  Try to see what requests were arriving about the same time.
Bernie.
JD1016
Yeah, I caught that too.  They basically codify what they are already spelling out in ArcGIS Server Manager ever so cryptically. Thanks.
