ArcGIS Server automated load test simulation tool?
10385
6
08-25-2010 04:43 AM
JerryGarcia
Are there any tools available to perform simulationed load tests against an instance of ArcGIS Server?
For example, I would like to register a bunch of map and image services.  Then, run a tool which would allow me to simulate different amounts of users performing actions on the services to see how the server responds.
All suggestions would be very much appreciated!  Thanks!
MichaelYoung
Hi Jerry,
Some of the more common performance testing tools utilized with ArcGIS Server include LoadRunner, Silk Performer, Visual Studio Test Team Edition, and JMeter.  Additional information about performance testing may be found in our Dev Summit presentation from earlier this year at: http://proceedings.esri.com/library/userconf/devsummit10/papers/tech/2010_arcgis_server_performance_...
LarsHuttar
You might also try PushToTest TestMaker (open source). It's not specifically aimed at GIS apps, but it IS specifically aimed at load test simulation, and is pretty good at simulating user scenarios, across multiple test nodes.
BrettElliot
BrandonKeinath1
Brett,
We've been trying to use Jmeter with some of our internal services and have had trouble.  We think we're handling the https portion correctly but still get errors.  I can post back with the specifics if someone would find that useful but perhaps there is another example out there for secured services?  I too really like tereshenkov's blog.
Has anyone used System Test to test service loading?
JayJohnson6
https://www.arcgis.com/home/item.html?id=a269d03aa1c840638680e2902dadecac#!
MXD PerfStat is what ESRI Professional Services would use.
JacobBoyle412
The tool to do that would be System Test for the Web.
https://www.arcgis.com/home/item.html?id=e8bac3559fd64352b799b6adf5721d81#!
This is an Esri PS tool.
Jacob is a Sr. Solution Architect for Esri Professional Services and loves conservation planning, woodworking, LEGO, and his dogs.
