ArcGIS Server 10.7.1: Map services published with ArcGIS Pro fails to recognize “SOE” capability,
1266
09-20-2020 01:10 AM
JamalNUMAN
Legendary Contributor
I couldn’t figure out why map services published with ArcGIS Pro fails to recognize “SOE” capability.
Jamal Numan
by Anonymous User
Not applicable
Hi Jamal,
It looks like you may be encountering the following defect: BUG-000110249: The option to enable Server Object Extensions (SOEs)..
For ArcGIS Pro 2.2+ and ArcGIS Server 10.6.1+, you need the Enterprise SDK to extend the functionality of map services published from ArcGIS Pro to use SOEs and SOIs.
See the following documentation for more information: ArcGIS Enterprise SDK
Hope this helps!
Calvin
JamalNUMAN
Thanks Calvin
In which sense I need “ArcGIS Enterprise SDK” in order to get the SOE option available for services published by Pro?
Jamal Numan
